My scooter's stop lights have stopped working when I apply brakes, however tail light still works. I checked for a loose connection but all seems ok. It's a Honda activa
Check the following:
the bulb: it has two filaments one can work while the other has failed
supply to the switch: if no supply check the fuse.
check the switch goes live on the output when the brake is operated.
does the socket get a supply when the brake is operated - if no and you have checked the switch then there is a break in the wire to be found.
1As an electrician I started to notice the fault was often the other end from where you started... but the bulb is normally the easiest to get to and check. – Solar Mike Jan 7 '18 at 19:30
As a #5 I'd check for corrosion in the socket which could be blocking contact to the brake light pin on the bulb. – GdD Jan 8 '18 at 9:38
Bulb is all ok.checked for fuse and supply also only thing remaining is the faulty switch but I am not able to locate that.Any idea where it could be located and how it looks? – DhKo Jan 8 '18 at 9:39
Check the combi break, may be the cables are wrong fixed, check the combi break unit. Same issues happed to me.
