My mustang will not move in first or second or 3rd gear but will in 4th gear. I really need some advice regarding the issue. It is rattling when the pedal isn't engaged.
I recently paid for a new kit (clutch, pressure plate, throw out bearing, pilot bearing, all came in the clutch kit I provided to the shop) to be installed but clearly, something was halfway done.
This time I'm going to do it all myself. I recorded my issue so please view it an give me an opinion of what you think Link-https://m.youtube.com/watch?v=KUdHV14u6SE
  • Welcome to Motor Vehicle Maintenance & Repair! When you said you "paid for a new kit to be installed", what do you mean by "kit"? Jan 3, 2018 at 7:24
  • Clutch , pressure plate,throw out bearing, pilot bearing , all came in clutch kit I provided to the shop Jan 3, 2018 at 7:49
  • Are you sure the gearbox itself is ok? Is 4th a direct connection between primary shaft and output shaft while 1,2 and 3 are via the layshaft - which could mean the layshaft has a problem especially as you mention the noise made. You may need to have the transmission checked...
    Jan 3, 2018 at 8:40
  • I'd also wonder along those lines if it was moving in those gears before the clutch install. Jan 3, 2018 at 8:45
