I own a dominar 400 and I have ridden 11K kilometers (Completed 3 service last month). I had an issue with throttle lag before and the service center said it will be fixed by an ECU update. After the ECU update when you shift to the first gear sometimes, the bike turns off. It can be started again with the self-start and it won't happen If you hold the throttle a little(Kind of like slow speed issue). When it turns of it feels like the fuel is cut off. Also, there is a missing feeling when I ride the bike. I have taken it again to my service center and with not much help (That day dominar service personals where on leave also there attitude is like the bike is still running). This gets little frustrating when you ride in heavy traffic.
My question is what all specific things should I ask the service personals to check like on my old bike we could ask to adjust slow speed or replace the accelerator cable etc since this bike is fuel injected I don't know much. The service centers electronic diagnosis couldn't find anything last time, the engine oil level is fine. Mailed bajaj customer care didn't get any reply. So if someone could figure out this could be the issue or you should check these components please help.
