Braking otherwise works fine, but I hear the click everytime I push the petal. I don't hear it if I'm in a stopped position and pump the breaks.
  • Welcome to Motor Vehicle Maintenance & Repair! Does the noise happen in forward and reverse? How much meat is left on the pads? – Pᴀᴜʟsᴛᴇʀ2 Dec 29 '17 at 15:31
I have found a few things that can cause this issue. If the anti rattle springs/ shims are worn or rusted the brake pad can shift forward when the brake is applied. Worn or loose caliper slides can allow the caliper to rock when the pad squeeze the rotor.
Attention! sounds like a caliper got loose.. check its two attaching bolts. They should be torqued to about 40-50Nm, roughly half of force you use to tighten the wheel bolts. And if they are not rusty, don't use grease, factory even uses loctite.
