I have an Opel Astra H Caravan 2008 1.7 CDTI 81kW (type 0035/AHO). I recently changed the oil, but I'm not sure if I used the right oil filter. I purchased two of them:
This type of filter was in the car before:
In the car was the first one (from amazon), this is why I choose to replace it with the same type. Ebay however says, that this is not the right type for this engine. The first one has a rubber gasket on both sides. The measurements, though, are the same.
I am a little bit worried. Should I replace it rather with the first one?
