I have a '99 Subaru Legacy Outback, and I'm working on getting the engine (EJ25) back into the car after replacing the head gaskets. I got the four bolts that attach through the transmission tightened already, but when I set the engine down, the bolts on the bottom don't line up with the engine mount slots on the frame.
Last time I had the engine out, I was able (after like 4 hours) to get it lined up by lifting the engine up and backward with the cherry picker. That didn't work this time. What can I do to get the engine shifted backward that inch or so?
