I have a 2006 e-150 that needs a transmission. The transmission I took out was a 4r70w. I found a 4r70w out of a 2000 e-250 on ebay. Can I use that transmission as a replacement? The seller only listed 2000 vehicles as being compatible. It looks like the one I pulled out though.
  • Did the buyer check for all possibilities or just assume the year of his / her vehicle? – Solar Mike Dec 13 '17 at 16:27
  • Seller, sorry. Im not sure if the seller provided a full list. – dolphone bubleine Dec 13 '17 at 17:05
    I'd assume there were differences and either get the one that was pulled rebuilt or find an exact match Y/M/M etc... You may want to call a trans shop to verify. NAPA shows different part numbers for overhaul kits so I'd say they are not the same. – Ben Dec 14 '17 at 0:11
  • Ratios and torque converter characteristics are likely to be different. – blacksmith37 Mar 16 '18 at 15:37
Unfortunately, it appears that the electronics of the transmission changed from 2000 to 2001. Source: F150 online
