What does DOT3 brake fluid do to ABS type plastic?
    If you get it off quick enough nothing, otherwise it's an excellent paint remover and may degrade the plastic as well...
    Commented Dec 10, 2017 at 22:07
  • Welcome to Motor Vehicle Maintenance & Repair! Commented Dec 10, 2017 at 23:25
DOT3 should not affect ABS plastic. It is only detrimental to natural rubber and paint. It also absorbs water, which may cause rust/corrosion in steel brake lines. Other than that, you shouldn't have any issues with it on plastic of pretty much any kind.
