Recently I had bought the new pulsar 220F (about 8 months ago) and now I am facing a strange sound in my bike. First the bike seems to work in normal condition and after 5 10 minutes, the bike feel like it's tired now. Engine become harsh and vibrate little more than normal condition. Pick up also decreases. In normal condition I could go to 40 kmph in 3 gears easily. But when the sound changes and pick up decreases, it gives a harsh sound in 3 gears when I reach to 37 - 38 kmph. I am also facing low mileage (about 25 kmpl) in city traffic.
I even went to bajaj showroom long time ago and they said tappet was too tight and they fixed it. But the problem is same now.
8
    Welcome to Motor Vehicle Maintenance & Repair! Dec 8, 2017 at 13:51
  • Considering this is a new bike, it is recommended you take it back to the dealership where you purchased it. If you try to fix things yourself, it may void the warranty.
    – CharlieRB
    Dec 8, 2017 at 14:06
  • Doesn't anyone here have recommendations for this problem?
    – viper
    Dec 22, 2017 at 3:58
    Running on a wrong type of engine oil might make symptoms like these. Correct me if wrong.
    – devst3r
    Jan 1, 2018 at 11:45
  • Does the quality of petrol also affect in the vibration? @devst3r
    – viper
    Jan 2, 2018 at 6:58
Since the Motorcycle is new and is on warranty period, As CharlieRB suggested, you have to take the bike to an authorized dealer and explain them the problems. Below i have described some possible situations that match your problem.
  1. Chain alignment issue
An improper chain alignment can cause vibrations and rattling in higher speeds and also in different gears. In most of the pulsar bikes, the chain will touch the center stand when it is loose. make sure the sound is coming from the engine side.
  1. Cam Chain / Timing Chain
If the sound is from the engine, it could be because of a loose cam chain and can also be heard slightly even in idle state. In this case you just have to ask mechanics to tight the cam chain inside the engine.
  1. Spark Knock
As described in this website (website link), the some signs of a spark knock pretty much matches your problems. It might not be a spark knock at all, try running on a octane petrol. premium or speed petrol as we say in India. If there is no such problems after, there is a chance of spark knock.
