In a guide to parsing Volvo paint codes, it says the following:
The fifth digit stands for:
1 = solvent based
2 = water based Metallic/Pearl + Varnish
3 = water based Solid + Varnish
4 = solvent based Solid + Varnish
5 = solvent based Pearl shine + Varnish*
6 = water based Solid/Metallic/Pearl + 2 component Varnish
7 = water based Solid/Metallic/Pearl + powder Varnish
8, 9 = not used
I can't figure out whether the slashes mean that these things are the same, or whether it means that the code means different things depending on the year/model of the car. For example, does "water based Metallic/Pearl + Varnish" mean that water based Metallic is the same thing as Pearl + Varnish, or does it mean that code 2 is water-based metallic for Volvo 850s, but Pearl + Varnish for later models (V70 or later)?
