7
I just had a new set of tires put into my Honda CRV. The lug nuts were torqued at 80 ft/lb (manufacturer's specs). The installer told me to come back to retorque the lug nuts after 50 miles.
If the lug nuts were already set at manufacturer's specs, should I even retorque them?
    Welcome to Motor Vehicle Maintenance & Repair! Commented Nov 27, 2017 at 2:10
  • re-torquing is primarily important with alloy wheels that have flat seat nuts. That is I think extremely rare / non-existant for modern OEM wheels, but if you have aftermarket alloys that may be the case. Of course it doesn't hurt to check.
    – agentp
    Commented Nov 27, 2017 at 17:02
8
It's just a double check to ensure the wheel hasn't settled onto the rim. If it has, even just a little, lugs can come loose over time. By re-torquing the lugs, you greatly reduce the possibility of it ever happening. If you have a torque wrench and the proper socket, you could do this yourself.
To be honest with you, I don't trust the torque the guys at the shop put on the wheels in the first place. Many are entry level tire changers who have no clue how to correctly operate a torque wrench (if they even use one in the first place). I loosen the lugs and re-torque correctly just to make sure. Most of these guys don't under torque anything, they usually over torque ... by quite a bit.
8
    it’s funny, you see people gunning on wheel nuts with a 1/2” impact, go around multiple times and then break out the torque wrench.
    – Ben
    Commented Nov 27, 2017 at 12:18
  • Don't most big shops use the impact torque bars now that just snap onto the impact gun?
    – JPhi1618
    Commented Nov 27, 2017 at 15:09
  • @JPhi1618 - They do, but they really aren't that good. They get you in the neighborhood, but don't get it as good as a torque wrench. Even when I've seen guys use a torque wrench, they don't know what they're doing and over tighten the lugs. Next time you get your tires changes, watch what they do and don't focus on "just one guy". Some of them might be doing it right, but I've found it to be hit or miss. I just don't trust them. Commented Nov 27, 2017 at 15:17
    I've seen it too @Pᴀᴜʟsᴛᴇʀ2, they hit the breakaway point on the wrench and they keep on tightening anyway.
    – GdD
    Commented Nov 27, 2017 at 15:27
  • it is possible to use an impact wrench to spin nuts on without tightening them much. Of course when you go back with the torque wrench they must turn some before reaching the correct torque, else you have no way to know if they are correct vs over torqued.
    – agentp
    Commented Nov 27, 2017 at 16:55
