inside my car I need help, I’m learning about my car, and I can’t seem to find an answer on what this part is, due to not knowing what it is, and not knowing how to ask google. It’s the part with a crack in it.
Any help would be greatly appreciated.
That would be the exhaust manifold : brown in colour with the vertical crack. The part that is screwed into it with the wires is the oxygen or Lambda sensor for the emissions / engine control.
  • if the answer is good enough then you can give it a "tick" as accepted. Bu you're welcome anyway :)
    Nov 25 '17 at 17:19
    While Honda parts are typically high quality, you may want to consider a quality aftermarket manifold. Some will have a lifetime warranty. They look at where the OEM part failed and correct the design flaws.
    – mikes
    Nov 25 '17 at 22:33
  • I've replaced a Honda manifold which cracked in exactly the same place @mikes. I doubt this is an isolated incident and getting an aftermarket part is spot on (besides, Honda charges OUTRAGEOUS prices for parts). Nov 27 '17 at 16:07
