https://www.reddit.com/r/CANBus/comments/39pzpp/bmw_3series_2015_odometer_reading/ I am using the above website as reference and sending commands to engine ECU. I have a log from BMW engine ECU (below):
6F1 12 04 18 02 FF FF
612 F1 10 17 58 07 4D FF 21 <DATA ERROR
6F1 12 30 00 00
612 F1 21 49 93 21 4A B8 21 <DATA ERROR
612 F1 22 4B F8 21 49 A3 21 <DATA ERROR
612 F1 23 4C B4 21 4C 18 21 <DATA ERROR
The log shows that 6F1 is the address for query to the engine ECU and 612 is the address for engine ECU response
Below are the Commands I send using PuTTY (similar to HyperTerminal):
AT Z (reset)
Reply: OK
AT SP 6 (set protocol 6, i.e. CAN 11/500)
Reply: OK
AT SH 6F1 (set header to 6F1)
Reply: OK
AT CRA 612 (receiver address set to 612 for engine)
Reply: OK
12 04 18 02 FF FF
Reply: NO DATA
12 18 02 FF FF
Reply: NO DATA
18 02 FF FF
Reply: NO DATA
I have tried all possible combinations but can't get the fault code. Can someone tell me the exact command I should hit to get BMW engine DTC?
