Car: 2004 Honda CRV-EX (the moonroof one)
Miles: 220k~
Issue: I had cylinder misfires before on this car and they were fixed with new sparkplugs and ignition coils.
Recently I've had more misfires and high engine temps. My starter died and I replaced it then things were ok.
Last week I had lots of trouble starting my car, got it started and it was driving ok then the engine kept sputtering and died. I opened it up to change the spark plugs and I discovered that the C4-Ignition Coil was melted and broken.
I replaced all the plugs and the coil and the car now just whirrs and doesn't turn over. Any solutions as to what I should do next to troubleshoot this? Do I need to reset the car's computer? Did it go into some kind of safe mode because of the issue?
EDIT: I had noticed high engine temps and I burped the radiator but I found out that the coolant in the reservoir was boiling which meant a bad radiator cap or thermometer. I have replaced both.
Update
I performed a compression test and I got some great results...
C1-50-55 | C2-0 | C3-10-15 | C4-50-55
So where do I go from here, what could be the problem? Is it the gaskets?
