  • Cranks but won't start
  • The fuel pump cuts on and I'm getting fuel up to the filter so halfway
  • I'm getting spark cause it starts off starting fluid
I've tried everything. Any help would be appreciated.
  • What exactly is everything? What kind of pressure are you seeing at the fuel rail? Is the immobilizer active? OBD2 codes? EOBD2 codes?
    – Ben
    Oct 31, 2017 at 21:46
It looks like your issue is with fuel supply. Possible things to check for:
  • a clogged fuel filter
  • a bad fuel pressure regulator
Both of these can cause insufficient pressure in the fuel rail, resulting in a lack of fuel delivery to the cylinders.
