I have a 383 stroker blueprint motor brand new has a new heater core thermostat and water pump I have drove it about 40 miles temperature gauge State about 190 degrees and did not blow out any heat through the heater and has poor circulation what that because through the water pump or a radiator
    Did you bleed the water system properly? An air-lock could be the issue - are the pipes connected correctly? – Solar Mike Oct 26 '17 at 4:15
    You did remove all the pipe blanking plugs before fitting the coolant pipes? and check nobody had stuffed a rag up there ...? – Solar Mike Oct 26 '17 at 8:53
    I’ve seen exactly what @SolarMike is referring to on a number of used or new engine jobs that come in for over heating or no flow to the heater core. Pull a hose and find that someone left a plug in. – Ben Oct 26 '17 at 13:33
I suggest that you :
1) drain the fluid : catch it all and check the amount against what it says in the manual.
2) remove all the pipes and check for any obstructions - note a rag may have travelled further up the pipe by now - a wire "hook" can help - if it comes back with fibres on it then....
3) refit the pipes and refill the system making sure that the correct amount goes in.
4) bleed the system as per the method in the manual - some vehicles like to have their front raised , other have air bleed screws in vital places.
5) hopefully enjoy the ride as all will be ok .)
| improve this answer | |
