I have an Acura legend (1995) that I did a header swap on and replaced the o2 sensors. They aren’t connected as of now and the car is running rich because of it. If I wanted to trick the car into burning less fuel with the o2 sensors disconnected, how much voltage would I need to put into the wire leading back to the ecu from the sensor wire in the harness(assuming I differentiated it from the heater wires already).
P.S just disregard the fact that I unplugged it and whatever it was just to setup a situation, just how much voltage should I put back into that wire?
