My Toyota Corolla is making the weirdest sound when braking (not squeaking). You can see the video on this link: https://photos.app.goo.gl/ylg43UksyJUS4pRj1
Now, I just went to Kal Tire, they did some work on my brake pads and rotors, charged me $700 for teh service and the noise is still there. I thought it was kinda weird since a problem on the rotors would me make more of a squeaking sound rather then the noise my car is making, right?
So I don't know, would you guys be able to point me in the right direction of what that might be, or maybe how can I diagnose it.
    Is it coming from the rear? Do you have drum brakes? – Ben Oct 20 '17 at 20:49
  • $700?? I hope you got all brand new rotors, pads, lines, fluid, etc., for that price! – Jimmy Fix-it Oct 20 '17 at 23:02
  • Hey @Ben yes I am pretty sure they are drum brakes. Which would make sense, right? that "spring" like noise – Lucas Storti Oct 23 '17 at 20:13
  • That’s what it sounds like to me. It’s hard to tell from the video but that’s the kind of noise you hear when drum brakes aren’t adjusted correctly or theres a broken spring. Might want to take a look at em. – Ben Oct 23 '17 at 21:16
This could be a couple things...
  1. Your new rotors could be warped. Although this isn't common, there is a chance.
  2. Your caliper could be loose- its possible the mechanic didn't torque your calipers to spec, which is creating the weird noise you are getting.
Honestly, I would just bring the car back to where it was serviced and get it looked at. They should be able to diagnose pretty quickly.
  • Very interesting, thanks for your response man. I will do some googling around those. I really didn't want to go to Kal "blind" again and they charge me another $700 to not solve the problem – Lucas Storti Oct 23 '17 at 20:11
protected by Community Oct 3 at 1:25
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site (the association bonus does not count).
