Does this car have any fuse for the cooling fan? My car had overheated and the temperature light has come on and my AC blows out hot and the fan does not turn on.
    Which engine do you have? There are differences between the 1.4 and 1.8. If you look at the underhood fuse box cover the fusible links and or fuses should be labeled.
    – Ben
    Oct 18, 2017 at 23:08
  • Just in general, everything in a car will lead back to some type of fuse. Without a fuse a simple electrical short in a bad motor or actuator could cause an electrical fire.
    – JPhi1618
    Oct 19, 2017 at 14:28
