I'm the lucky owner of a 2007 Peugeot 307.
It is born with central locking. However it only works using the remote. So if I use the key directly in the lock cylinder (the only lock on the car is in the driver side front door) then it opens the door, but the central locking is not activated. What could be wrong, I have no clue?
8
  • Welcome to Motor Vehicle Maintenance & Repair! I'm reading here, you are expecting the key to automatically lock all the doors for you when you lock the driver's door? Have you tried turning the key a second time? Oct 18, 2017 at 17:05
  • Hi! Good idea! Just went out in the driveway and tried it out. Unfortunately, no luck. The only door that locks/unlocks is the driver door it self. None of the others respond. It doesn't sound like the central lock kicks in at all
    – Niels
    Oct 18, 2017 at 17:47
  • Second thing to try is to turn and hold in the lock position. One other thought ... are you sure this is irregular behavior? Oct 18, 2017 at 17:52
  • @TerryGould as stated in the question, the only lock on the entire car is in the driver side front door unfortunately.
    – Niels
    Oct 18, 2017 at 18:06
    If the key is supposed to activate the central locking system, there's a microswitch in the door latch, and that can break/wear out.
    – JPhi1618
    Oct 18, 2017 at 19:34
