My Car Vauxhall Astra Club Twinport, Maual, Petrol, 1598cc, 56 plate is currently showing constant engine light, which means there is some fault, but the car works fine. Using the petal test I got Error codes
- 013007
- 013500
- 014100
- 040062
- 044306
- 111206
- 111606
- 000000
I read few forums which says check the fuse first, but I am not sure which fuse. So I am planning to check every fuse by taking out and inspecting visually, while keeping the car off.
Two questions.
- Am I OK to remove fuses randomly from the fuse box and check them?
- From the error codes above could anyone tell me what could be the issue?
