2008 Chrysler Town & Country, 3.3 flex fuel V6, 170k miles.
Random misfire code, shaking upon startup and very bad with no power when it's put in gear, stops happening after I get going, like even a house two two away. You can smell gasoline from the exhaust when it's first going.
I just did plugs and wires to no avail. The coil pack has been replaced a couple times and I would have assumed that was it again except it only happens at the start. The van has no problem starting up.
What should I look at first?
Side note, and I hope this comes up in searches: for anyone thinking about getting one of these cars or any Chrysler/Dodge/Jeep, just don't. Four brake jobs in 3 years, 3 coil packs, misc coolant leaks, new radiator, new alternator, new fuel injector. Worst thing about the coolant leaks is that the climate control system sucks the vapor right into the cabin, slowly poisoning your family.
