The low beams on my 2011 GMC Sierra 1500 are not working. My high beams work in both switch positions. What is the simplest and cheapest way to fix this problem?
Welcome to Motor Vehicle Maintenance & Repair!– Pᴀᴜʟsᴛᴇʀ2 ♦Oct 14, 2017 at 13:18
A 15 amp 15 cent fuse would be the cheapest fix :)– user38183Dec 9, 2018 at 12:24
1 Answer
Check a fuse or relay leading to them from your users manual would be a cheap easy fix if one of those went
