I am wondering where the turn signal flasher for a 1987 mazda b2000 is located? My turn signals don't work, but my hazard works. Is there a separate relay flashers or, is it a fusable link?
  • I have the same issue with my 84 B2000 All my lights work but when I put the indicators on they just turn on instead of flashing, the hazards flash thoguh. – Xander Baker Jan 10 '18 at 8:34
Could be as simple as a fuse. (NOT a fusible link.)
The hazard system is on a separate fuse that allows operation even with the ignition off.
Do the reverse lights work? That's an important clue.
If the hazard lights flash, it's not the flasher module.
Here's a wiring diagram that should be very similar to your truck:
Mazda 1987 B-series trucks Hazard and Turn
