I need to add a cable into an existing plug for a 2007 Subaru Legacy (BP) vehicle.
For practice I picked up an identical plug from the wreckers. Figured I could use the pin and cable from the test plug on the real project.
These things are small (plug body 24mm W x 16mm H ) although each connection has a hole right above (or below?) it.
You might see from the photos I've tried using a small screwdriver and needlework pin to release the cable with no luck. Any tips appreciated.
UPDATE: The holes for the extraction tool seem to be below each connector and when removed the crimped side of the cable entry points downwards. Tried various implements to extract the pins but did not purchase a specific tool. Only the hacksaw approach worked for me.
