I just got my jeep back from the mechanics i had to replace my power steering pump and today i noticed a green liquid leaking from under my jeep i checked the fluid its 100% engine coolant i checked around my entire reservoir no leak anywhere around it all hoses in place and tight. its more by my engine block i'm so scared when they were fixing my power steering pump they somehow cracked my radiator i just paid 490 some to replace my pump so i have no clue what to do can someone please tell me what it could be cause i cannot afford to go back to the mechanics
  • Welcome to Motor Vehicle Maintenance & Repair! Which engine is in your Jeep (4-cyl or 6-cyl)? – Pᴀᴜʟsᴛᴇʀ2 Oct 2 '17 at 18:28
  • +1 Can we give the OP some upvotes so they can post an image of where they're seeing the coolant.. – elrobis Oct 2 '17 at 20:11
  • OP if the water pump was just replaced, it's possible the techs, for whatever reason, didn't get a good seal at the gasket. What do you mean by "just" replaced: Two days? Two Months? There may be a warranty for the work. – elrobis Oct 2 '17 at 20:42
