I have a honda 125 cc bike. Recently i have found some problem with the accelerator. Accelerator automatically getting raised . I am not sure whether it is problem with accelerator.I have changed my accelerator cable twice. But the problem still persists. I have consulted with two mechanics, but they said they didnt saw any problem with the bike. Can any one have any suggestions.
  • What do you mean "raised" ? It sticks open? It closes automatically? It accelerates by itself ie continues to open until full throttle?
    Sep 30 '17 at 8:12
  • It accelerates by itself. Continues to open until full throttle
    – Sans
    Oct 5 '17 at 4:44
  • Is there a blockage in the carburettor causing the piston to rise? Check the air channels and make sure they are clear
    Oct 5 '17 at 6:33
  • Ok. But i feel some tightness in the accelerator. Is the carburetor issue cause any tightness in the accelerator??? I have replaced the accelerator cable twice, but the issue still persists
    – Sans
    Oct 5 '17 at 7:00
If its carbeurated you could have bad carbeurators or floats. If so, CAREFULLY clean them and finely adjust them and the throttle body. -not responsible for lost carb parts and maybe adjust the idle?
