I have a 2004 Renaultsport Clio 182. I was toying with it yesterday and had the car in first gear, clutch flat to the floor, and I revved the car. At around 6000 rpm I felt the clutch bite and the car pull forwards slightly.
What is the cause of this?
  • 3
    Friction drag as the gap is only small and the fluid (air) between the plates can transmit power if the speed is sufficient.
    Sep 27, 2017 at 11:43
  • Is this a sign of clutch deterioration? Sep 28, 2017 at 8:28
  • No - as the clutch plate wears the gap gets bigger...
    Sep 28, 2017 at 8:30
