Someone put replace the front left tire with the spare one and left this outside :O What is this? It seems worn out a bit. Should I worry?
Car: Mercedes 09 ML350
8
  • It's hard to tell from the picture what material that's made of, is it plastic, metal or some combination?
    – GdD
    Sep 20, 2017 at 22:13
  • @GdD The outside is plastic, but no too light.
    – Bill roy
  • Are you positive that came from your car?
    – 3Dave
    Sep 20, 2017 at 23:33
  • Please, edit your answer, using proper grammar, for sentence structure. Sep 20, 2017 at 23:48
  • I understand, you're trying to identify the piece here. But I can't comprehend to full extent what you went through. Share all 6 sides of that part as images. Sep 20, 2017 at 23:49
It is called "jack pad" which is used in elevating the car when changing tire or other mechanical inspections. It's attached under the car (somewhere around the side edge of the chassis).
https://www.google.com/search?q=jack+pad+mercedes+2009+ml350&oq=jack+pad+mercedes+2009+ml350&aqs=chrome..69i57.238j0j1&sourceid=chrome&ie=UTF-8
