2001 Toyota Sequoia horn works sometimes. I changed the fuse. Is it possible that the relay is bad? How would I know?
Welcome to Motor Vehicle Maintenance & Repair! – Pᴀᴜʟsᴛᴇʀ2♦ Sep 20 '17 at 0:27
Are the connections to the horn loose?Check the connecting wires it should be firm – DhKo Sep 20 '17 at 6:41
@Pᴀᴜʟsᴛᴇʀ2 thanks, might be in over my head though! – Rod Sep 20 '17 at 16:07
You will have to test the system logically :
1 supply - is it intermittent
2 switch for operation
3 supply to relay
4 relay
5 supply to horn
6 horn
7 earthing of horn but you can do this first as it is a common issue.
For testing use a test lamp or multimeter : lamp probably better in this case as it gives a more "visual" response when power is there...
This is a great list of things to check. How would the OP go about checking any single part you've mentioned? A list of bad parts is great, but instructions would make this answer great! – Pᴀᴜʟsᴛᴇʀ2♦ Sep 20 '17 at 18:49
