2006 Buick Lacrosse CXL I'm replacing the outer tie rod. I have been unable to find the torque spec for tightening the castle nut which holds the tie rod end to the steering knuckle. Does anyone have this spec or know where I can find it? I used to look in the Haynes manual, but the auto stores no longer keep them in stock. Thanks
@SolarMike I have the manuals for our other vehicles, but they don't stock them for most vehicles anymore and I don't have time to wait for it to come in the mail.– denverSep 17, 2017 at 11:50
1 Answer
Here you go,
"Tighten the nut to 30 N.m plus 120 degrees (22 lb ft plus 120 degrees). Inspect to ensure that 21/2-41/2 threads are visible above the nylon washer."
