2002 Highlander Brakes very low to floor. Work find just low. Had new Calipers put on one year ago 1313 miles ago.What should be replaced???
  • The first hing you need to do is check the brake fluid level, what is it at? – Ukko Sep 6 '17 at 18:00
  • Do you ever use the parking brakes? I've seen that can be a part of the rear drum auto-adjustment. Try appying the parking brakes fully and then the regular brakes. Make a series of forward and reverse stops using the parking brake between to try and allow them to auto adjust. – JPhi1618 Sep 6 '17 at 19:54
  • Parking brake not working Around 300.00 to fix – William Gardner Sep 6 '17 at 20:35
