I have a 2004 Volvo S40 that when starts it'll stall. It'll run for a minute or less before acting like it's starved for air. Get the codes P0339 which is a crank position sensor. I have replaced it and I still get the same result. I've charged the battery also. The codes read 1st P0339 and a 2nd code that is P0339 with a pd looking symbol next to it. I've verified the connections on the connector also.
Possible Causes of P0339 Code: Crankshaft Position Sensor 'A' Circuit Intermittent
Highlighted items are ruled out as already addressed.
Faulty crankshaft position sensor- replaced
Crankshaft position sensor harness is open or shorted-checked
Crankshaft position sensor circuit ?
Poor electrical connection ?
Signal plate may be damaged ?
Starter motor may be faulty ?
Starting system circuit ?
Dead or weak battery-recharged
Symptoms: Check engine light activation, loss of power, engine stalls
Try replacing battery. This might resolve the problem as a weak battery could trigger this code. Maybe starter issue.
This may not give a definitive answer but gives avenues to check next.
