Just put new struts and control arms on a 2010 but, and the wheels have negative camber now. They don't have any adjustments on the new struts, how do I get the wheels back straight.
    Make ,model and year of manufacture, front or rear, goes along way in getting responses.
    – mikes
    Aug 27, 2017 at 22:13
  • Double what @mikes said. Aug 27, 2017 at 22:17
  • post what @mikes said, but it will be best for you to visit a wheel alignment store, getting 0 from household method is nearly impossible
    – Nilabja
    Aug 28, 2017 at 5:07
  • If the camber is so obvious - have you fitted the correct parts?
    Aug 28, 2017 at 5:18
From my experience, I have seen on many cars that the bottom two bolts and nuts on the spindle onto to the strut will allow a very small amount of movement for back and forth (before you tighten them all the way). Make sure you put them exactly where they were before, this can affect the camber.
