During a long road trip I have been periodically checking the engine oil levels every 500ish miles. However the last time I did it on a dusty dirt road off the side of the highway.
1) Could the dust/sand/insects from the air have made its way into the oil via the dipstick hole and cause damage?
2) Could the dust/sand from a dirty rag cling onto the dipstick and get in the oil and cause damage?
3) Would the oil filter be robust enough to catch this small amount of grit?
4) Is the movement of oil as such: sump (what dipstick measures) -> filter -> pump -> camshaft?
5) What type of damage occurs from grit in the oil?
I wouldn't say absolutely nothing made it's way into your engine via this route, but the dipstick tube is so small (relatively) and the amount of oil which can be on the dipstick is so small when you pull it out, even if some dust/sand/insects got caught in/on any part of this, it would amount to nearly nothing.
When you wipe of the oil, any dust/sand on the rag won't transfer to the dipstick unless you've got some serious crap on there. Easiest way to avoid it is to just shake out the rag. A couple of few good snaps with your towel/rag will get any dust/sand off of it and it will be ready for use. Anything else which may be on the rag won't transfer to the dipstick because it will be trapped by the rag itself.
Oil filters typically try to filter down to the 6-10 micron range. When a filter gets down to the 3 micron range, they start removing additives in the oil. Ultrafine dust particles refers to dust which is about 2.5 micrometers in diameter, nearly a 30th the thickness of human hair. The thing is, when dust is this fine, it remains suspended in the oil and doesn't cause any issues to the engine. Would a bunch of it cause issues? Absolutely, but the amount you are talking about isn't going to do much at all. The saving grace may be, if the grit is in the oil for any appreciable amount of time, cleaning agents will cling to it, causing it to be bigger in size, which will allow it to be trapped by the filter.
It depends on the oiling system, but usually it goes from sump -> pump -> filter -> rest of the engine. Some engines pump it to the camshaft and then down to the crankshaft. Other engines have what is called priority main oiling, which sends it to the crankshaft first, then out to the rest of the engine.
If enough grit which is not caught by the filter is in the engine, it can cause wear on the internal parts, including the crank & cam journals, bearings for each, cam lobes, cylinder walls, etc. Pretty much anywhere there are wear surfaces.
  • Thanks for such an in-depth answer, it definitely gives peace of mind! However, one last question: even if a small amount of sizable grit (not ones that would be suspended in oil) entered the engine, given that the filter is quite new and that the amount of grit shouldn't be substantial, would the grit be caught by the filter? And if it weren't, would the wear be similar to using old dirty oil? Aug 27, 2017 at 3:02
  • @user1950278 - Anything larger than about 6 microns is going to get caught by a reputable filter. In order for grit to affect your engine, it would have to continually flow through your engine. The filter is going to stop this without issue. Aug 27, 2017 at 12:11
Checking your oil level by the dipstick isn't going to cause a problem if you wipe it off before putting it back in. Your air filter/intake is where grit gets into the engine. You oil filter will remove it, but grit sucked in the front end does damage before it can be removed. If you do a lot of off-road driving or live in a dry/gritty place, you should ask your local auto parts store clerk what they recommend to add intake protection. Uni has been around for a long time and is well thought of. http://unifilter.com/ Their sock filter is like the foam filter most wet/dry vacs have. It slips over the paper filter and is washable/reusable.
  • Good succinct answer and for intakes another possibility is to use one of the "rotational" air intakes that swirl the incoming air and traps the dust that way : seen on many older Ford tractors as an example.
    Aug 27, 2017 at 7:35
