I have a safety question regarding a sheared exhaust pipe repair I performed on my 2002 Toyota Camry. I did the following:
-Cut up a steel can and fit it inside the two sheared ends of exhaust pipe.
-Used two stainless steel hose clamps to push the two pieces of pipe back together
-Applied Thermosteel 2400F Coldweld to cleaned up surface on the break, creating a seal. Then cured the putty.
Is there anything that I should be concerned with in terms of safety? Could there be any potential problems with carbon monoxide feeding into the cabin?
Thanks!
(the repair, pre thermosteel application)
