Trying to replace my window motor and regulator. Connected the new parts fine but can't seem to position the regulator correctly, the window fidgets around and every time I try and place the metal panel back on the door, the holes just don't line up, I can only ever get one bolt in. I tried it with the window up, with the window down. It seems like the brackets or whatever don't stay in place they just kind of sit in there free floating without any fixture in the door housing.
Please see this vid for explanation:
I've tried to mimic the regulator positions I'm seeing here: https://youtu.be/e_sMNdSMbV0?t=170 but I just can't get it.
Is there any indicator in the door housing of where it should be positioned, and how can I get it to not fidget and move once I screw in the motor? Because one of the motor is connected to the panel I have 10 times less slack on the panel and making adjustments is difficult.
