Does a 2003 Buick century have a timing belt?
Welcome to the site. First, is it a 2003 or 2004? It says both in the title/question. – kyle_engineer Aug 21 '17 at 21:58
The first Google result says it all: https://repairpal.com/when-do-i-change-timing-belt-404
This car has a timing chain. No timing belt worries, then. Also, no chain worries according to the link. Some cars with timing chains have a chain system that isn't good for the entire life of the car, but apparently your car doesn't have such a poor timing chain system.
The chain on those 3.4 and 3.8 engines will more than likely outlast the life of the car. – Ben Aug 21 '17 at 23:06
FWIW wikipedia says its a 3.1L. In case others come across this, where you need to worry about GM timing chains is on overhead cam motors (which he sure doesn't have in the Century) – agentp Aug 22 '17 at 13:29
