something got in and caused these scratches. can/will they cause blowby if reused?
I figure if the placement of its .018 mil piston ring gaps matter, then the gaps from these scratch just may as well. I already took off any high spots. and could cut the grooves again if need be.
of course new is usually better, but I'd like to determine if it is at all reasonable to reuse this piston.
