I have an '07 kow vulcan only 6k miles and recently rebuilt carb., now it is losing compression and is killing me to speed up even in low gear, could the clutch plates be shot even at this low mileage?
have you tested the compression?– CeshionAug 15, 2017 at 23:10
1Welcome to the site. What does compression have to do with the clutch plates? They are completely unrelated. I have a feeling something is going on with your bike and you're guessing at what you think it might be. Why don't you explain what's going on, in complete detail. Don't tell us what you think is going wrong, tell us what is happening when you ride your bike. We're here to help, but we can only help when you give us information without supposition.– Pᴀᴜʟsᴛᴇʀ2 ♦Aug 16, 2017 at 0:05
If the clutch is worn out, the engine will rev fine, but the bike won't accelerate.– MooseLuciferAug 16, 2017 at 0:06
How did you test the compression? What was the result? Has a setting slipped in the carb - since you mention that as previous work?– Solar MikeAug 16, 2017 at 6:18
