I have a heavy (65 lb) battery for my boat & live upstairs (no elevator) in a condo.
I don;t wanna keep bringing it inside to charge it & the only power plug I have outside is where I park my car. There is no power where I store the boat.
I have 2 cars, so could always take the good battery out of the car & put the dead battery in & charge it that way. What do u suggest?
Thank u
    Welcome to the site. Is there any sunshine where you store your boat? If so, you could always purchase a photovoltaic charger and attach it to the battery. As far as the battery itself goes, if it's used for a trolling motor, it's going to be a deep cycle type, which is not what is used in an automobile, so you couldn't just exchange it. You need some sort of charger on it. – Pᴀᴜʟsᴛᴇʀ2 Aug 12 '17 at 16:20
  • Another possibilty compared to a pv panel is a split charge system in the car - which would mean you have to lug the battery to the car but it would keep it charged... – Solar Mike Aug 12 '17 at 16:24
  • How often do you use your boat? If it's often, you may not need any separate charging. However, I don't see bringing the battery to your condo a problem; I used to live in 5th floor with no elevator and carried my car battery indoors when it needed charge. Some safety nazis, however, may have something against charging a flooded battery indoors. For seasonal uses, you could bring the battery indoors for the winter and have a trickle charger. – juhist Aug 12 '17 at 16:36
