2005 subaru forester x 77k miles replaced both head gaskets, timing belt thermostat and radiator. I purged the system also. I turned on the heater and no heat just cold air. The lower radiator hose and the heater hoses are also cold. Thanks Tom
  • Welcome to the site. Did you replace the water pump? – Pᴀᴜʟsᴛᴇʀ2 Aug 7 '17 at 20:51
  • Has the cooling system been pressure tested? That is similar behavior to low coolant. You could still be leaking. – finleyarcher Aug 7 '17 at 22:30
