This question already has an answer here:
I changed the oil in my 2004 cagiva raptor 125 (transmission) and i put back almost 1 liter of oil. The bike is supposed to have 800ml of oil in it. Is it going to harm it in any way?
marked as duplicate by Spivonious, Ceshion, Pᴀᴜʟsᴛᴇʀ2 Aug 3 '17 at 20:17
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
  • It might differ in a motorcycle – Andrei Grigore Aug 3 '17 at 18:23
Overfilling the oil can cause pressure to build up and potentially bust some seals. I would recommend just letting the excess out and stick to the manufacturer recommended volume.
If you really want, save a 1/5th of each liter, and every fifth oil change will be free :)
  • Makes sense. I'm going to drain out the excess oil tomorrow. – Andrei Grigore Aug 3 '17 at 18:24
  • Do you mind explaining how a high oil level can cause increased oil pressure in a traditional engine with an oil pump? – Ives Aug 3 '17 at 18:40
  • Too much oil can potentially cause some of the oil to burn (Crankcase breather >> air cleaner box >> induction sys). Burning oil can lead to a slew of problems incl broken seals, burnt valves, and fouled plugs. Maybe 200mL isn't enough to cause any problems, but I'd rather be safe than sorry. – Sage Aug 3 '17 at 18:44
  • Here's an article with some more explanation on the topic: cycleworld.com/2013/08/09/… – Sage Aug 3 '17 at 18:47
    If the extra oil is enough to hitthe crankwebs then it gets severly frothed up and blows the seals and other things ... but if you haven't seen it you won't believe... – Solar Mike Aug 3 '17 at 18:55
