As the title suggests there was this dent on my motorcycle and I'm not sure what happened. Any help is appreciated
1It got hit - assume when parked because you would know if it happened when riding. – Solar Mike Aug 3 '17 at 4:35
With so little information to go on, it could be anything. All we know is that it is a Honda and it has a dent. To me, it looks to be like it was knocked over (dropped) and the handlebar impacted the tank. – CharlieRB Aug 3 '17 at 13:12
Once, when putting my helmet on it slipped from my hand and hit the tank causing a small indentation I didn't notice till a day later. Not this size though. Seeing as it's along a crease line it would have to have been something pretty heavy. But also soft - there's no damage to the paint. Id' look around for something resembling a steel pipe wrapped in cloth... – MeltingDog Aug 3 '17 at 22:28
As I pointed out in my comment earlier - it has been hit - a possible guess is that a pipe or somesuch has been dropped or bounced off the tank.
The possibility of suction being the cause is, imho, very unlikely given the curvature of the outer tank panels.
I can think of two possibilities to this:
- A vent line has become clogged and this has caused a vacuum condition in your tank, causing it to collapse. I've you've noticed the fuel cap being difficult to get off recently this might be it
- The tank has been damaged by some sort of impact, either something being dropped on it or possibly a car/truck hit it when it was parked
1I don't believe suction could cause a straight line like that do you? And your point two reads much like my comment.... – Solar Mike Aug 3 '17 at 9:10
Suction is less likely but still a possibility that should be explored @SolarMike. Accident damage is a pretty obvious possibility, it's not as if I wouldn't have thought of it if your comment hadn't been there. – GdD Aug 3 '17 at 9:16
I've had accident damage before, came downstairs to find my handlebar bent. Someone had knocked my ride over and put it back up, then drove away, as if I wouldn't notice. – GdD Aug 3 '17 at 9:28
