enter image description hereHello this plastic cover that is in the green box is cracked after having a front-end collision and I need to replace it does anyone know the name of this part cheers.
  • When you go to the dealer just tell them it is the plastic shield behind the bonnet catch.
    Jul 27, 2017 at 13:47
  • @SolarMike - Maybe they don't want to get it from the dealer? Usually a lot more expensive than a used part, but you still need to know what to call it if you start asking at a salvage/junk yard or on the interwebz. Jul 27, 2017 at 14:10
  • @Pᴀᴜʟsᴛᴇʀ2 So plastic shield didn't do it for you?
    Jul 27, 2017 at 14:47
  • @SolarMike - I cannot see the image here at work or I'd answer the question for the OP. Jul 27, 2017 at 16:18
  • For future references, the website realoem.com is an online system to look BMW part numbers up. If you enter the last 7 digits of your VIN number it will automatically select the correct model.
    – Elias
    Aug 30, 2017 at 14:56
It is part of the air induction system. It is called a Suction Hood. BMW part number 13717541738. It can be found as #15 in the diagram below.
Source
  • I had an answer up, but yours is a lot more authoritative. Deleted answer and +1 to you. Jul 28, 2017 at 12:18
