I'm considering buying a car (2001 MR-S w/ 2zz-ge swap) that had incorrect injectors installed into 2 of 4 cylinders. Specifically, 260cc injectors were installed instead of the 320cc injectors it needed.
What damage can be caused by driving a car with incorrect injectors, and what symptoms may be noticeable in a car that has experienced this?
Also, if injectors are incorrect, is it worse to have injectors that supply too much fuel or too little fuel?
    I'd guess if it hasn't been tuned for the bigger injectors,you run the risk of the associated cylinders running lean. – Ben Jul 26 '17 at 23:28
    I think the ecu will notice the lean mixture from the o2 sensor and try rich-ing it as best as it could, of course the stock ones now will be rich and if the engine was to be put under high load the other 2 sensors wouldn't be enough for the demand and thus their cylinders will be lean. – method Jul 27 '17 at 1:59
