Car: 2010 Passat CC 1.8 TSI
There is no problem with the old gasket there is no leak i just remove the head because timing problem.
Cylinder head, i've cleaned the head with plastic tools and some cleaning materials looks fine i've checked and tested everything looks good.
Engine Block, i've cleaned the Block using razor blades and plastic tools now there is no gasket material and and the Block surface very smooth but not shiny (please see pics) there is nothing more can do using plastic tools!
How and what is the best way to clean the block for MLS Gasket?
