I just bought a 2000 Chevy s10. It shakes when accelerating moderately in gears 3-5 (manual transmission). If I accelerate very gently, it doesn't happen. There is also a knocking noise every 1-2 seconds when it is shaking (it sounds like it's coming from the lower driver's side of the engine bay, but I can't be sure because it only happens when the vehicle is moving).
It accelerates fine in 1st and 2nd, so I don't think the transmission is slipping. What could be causing this problem?
    You say "just bought" so did the car do this when you took it for a road test? Why not take it back to the dealer and get them to sort it? It could possibly be an engine mount but also many other things,
    Jul 16, 2017 at 22:09
  • @SolarMike Private party purchase.
    – Jacob
    Jul 16, 2017 at 22:11
  • @SolarMike How many other things? I'm not sure where to start looking, so I'm hoping for a list of things to check to narrow down the problem.
    – Jacob
    Jul 16, 2017 at 22:13
  • Check the U joints, if they are really bad you can move the driveshaft with your hand. If they are worn but real bad you have to remove the driveshaft and manually rotate the U joints to feel for binding.
    – mikes
    Jul 16, 2017 at 23:31
  • There's so many possibilities here, it could be worn tires, bad suspension, problems with the axle, the list goes on
    – GdD
    Jul 17, 2017 at 7:03
The problem was the U Joints. No other fixes were necessary to stop the noise or the vibration.
