Haven't had the best luck with tires so I'm pretty cautious (aka paranoid) about something happening to them. Took a turn an it too close today and rubbed my rear right tire along it at around 35 mph.. not a true gash but there is signs of running. Anything to be worried about? Should I apply rubber glue to the area? Possible risk of popping? Tires are Michelin premier a/s 205/50r17 93h XL BSW(whatever that means)
enter image description hereenter image description here
  • Welcome to the site! Jul 16, 2017 at 21:46
  • Not an answer to your actual question, but those numbers (205/40/17 93h) are width in mm, height between rim + tyre as a percent of the total width, alloy size in inches, load index, where the number 93 refers to the max weight per tyre (in this case 650kg) and the letter is the max speed allowed while carrying the max load. The "BSW" is just the style of the tyre.
    – Tas
    Jul 16, 2017 at 23:45
Kind of hard to see in the photo's, but if you could lift the tear and see the braids/strings(sorry can't remember proper term to save my life) then it's time to replace the tire. If it's just scratched/skinned the tire you should be ok
  • Agreed. This looks like it's just a rub on the sidewall. Happens all the time. Keep it on the rear for now. If it doesn't leak air and no performance issues (wobbling), there should be no issues going forward. Jul 16, 2017 at 21:46
    @cano plies or ply...
    Jul 16, 2017 at 22:09
  • Thank you all, there is a small piece of rubber that I can lift up but it does not seem to be too deep. Would there be any help if I applied a rubber glue to the area? Again, I really appreciate the replies, very helpful
    – katie
    Jul 16, 2017 at 22:10
  • @solar Mike, that's it!! Thank you and @ Katie go ahead, it won't hurt anything.
    – cano
    Jul 16, 2017 at 22:17
  • Take more pictures while holding the rubber lacerated portion on the tire. Fill the tires to the recommended PSI level. Monitor it closely for a few hours. If air is leaking more than 2 PSI in 1 hour. Change them according to the thread life and Drive terrain (on your unspecified/unlisted vehicle) Jul 17, 2017 at 12:45
