My 2012 Chevy Impala was doing just fine until two weeks ago. I auto started my car, while walking up it shut off on its own. I got in the car and the check engine light came on as well messages for service Stabilitrack and Service Traction (something, I can quite remember). When I am at a complete stop the car stutters with vibration. I got the ignition coil in Cylinder 1 as well as the spark plugs for cylunders 1-6 changed. The car now switches gears at the proper time but there is still a stutter, When the spark plug is removed from cylinder 1 the car runs fine without the stutter. What could this be?
2Welcome to the site. There seems to be more than one problem going on. Get the codes read and update your questions with what you find. That will give us a starting point in helping you figure out what is going on. Otherwise, all you will get are guesses.– CharlieRBJul 13, 2017 at 19:58
What do you mean "the spark plug is removed from cylinder 1 the car runs fine without the stutter"? You're saying with a spark plug completely out of the engine, engine running on 5 cylinders, it runs fine? Not seeing how this can be. Can you please explain?– Pᴀᴜʟsᴛᴇʀ2 ♦Jul 13, 2017 at 21:12
I took it to a mechanic and he is now sayin it is a fuel injector problem, The stutter is still there . Do you have an idea on how much this could run me?– Tanesha McFaddenJul 17, 2017 at 19:07
